Question about heat.
mats12
34
So I have made alot of posts here about related to my fps issues with games which sadly havent completely fixed. Long story short Im getting low fps in most of the games including low spec ones while few months ago I didnt have problem running higher spec games which was fine by me.
I tried lots of things like updating and changing drivers, downgrading to win 8.1 and much more.
I have 2 grahpics cards which are AMD 8610G HD(integrated) and AMD R7 M260 which is dedicated one and more powerful. Computer switches between cards depending if Im gaming or not which is fine by me. Issue is that dedicated card is getting absurdly high temperatures all up to 100 degress and even once 500 degrees(most likely sensor fault since it way too high) and I think it be reducing my computers peformance.
As for cpu and integrated they stay about 50-60 or so usually lower when idle.
Today I decided to take apart my laptop and see if there is any dust, which there wasnt, also had new thermal paste applied which didnt help either. (altho dedicated card uses thermal pad which might effect heat, but Im not sure).
Fan is also making weird buzzing noises all the time and which I have no idea what causes it since when I took it apart I didnt seem to find any issues. Funny thing is that fan speed lowers to 500 rpm when doing intentsive stuff and stay 900 rpm when idle which is kinda weird.
After cleaning sometimes when idle the cpu and integrated card start randomly producing heat, and lowering fan speed to 500 rpm.
Any ideas since I have nothing else and I have tried so many things to get my laptop to run games on decent fps.
