Question about mobos help please :)
sixsamuraisoldier
426
OK, so, I've been wanting to make a gaming god computer. So, my question is, are there any motherboards (i'll take server) that have:
128 gb RAM
2 CPUs
support for 4-way sli
4 pcie 3.0 slots (must be able to run x16/x16/x16/x16 simultaneously)
Must be socket LGA 2011
And one more quick question, if i get a server motherboard, would i be able to use the normal windows 7 ultimate 65-bit?
And, if i got a server motherboard, would i be able to use two i7-4960X(a desktop cpu), or would i HAVE to get xeons or other server cpus. thanks in advance :)
Your spec has 112GB too much RAM for any gaming machine = waste o' money
Dual i7 = nope... you would need server CPU's
There are boards with 4 PCIe x16 slots.
Windows 7 Ult 64 should install on server motherboards - check for driver support first though
You will get exactly 0% performance increase by having more than one CPU in a gaming machine (besides you will need xeons for multiple cpu's). Same goes for more than 16 GB ram.
If'n you really want a socket LGA2011 board there are some great options out there...and we can help. But I would stay away from server setups if I were you. They wont do what you are wanting.
