My nzxt tempest 210 didn't come with the bottom mesh filter that can slide out, but there's a place to put one in(like the other models that have the filter on the bottom that slides in, has the notches on mine too). I'm curious if there's a place to buy a replacement for one of these?
my case : http://www.amazon.com/NZXT-Technologies-TEMPEST-210-Midtower/dp/B0066130CM
The nzxt 210 case that is basically the same but comes with a mesh filter for the bottom, the case I have has a mesh filter on the front panel so I guess they decided not to add one to the bottom to cut the cost.
this is how the bottom looks
http://www.google.com/imgres?client=firefox-a&hs=fHB&sa=X&rls=org.mozilla%3Aen-US%3Aofficial&channel=sb&biw=864&bih=428&tbm=isch&tbnid=t-zPFZzrltFzwM%3A&imgrefurl=http%3A%2F%2Fwww.hardwaresecrets.com%2Fprintpage%2FNZXT-Source-220-Case-Review%2F1409&docid=O19wil0k-b3uTM&imgurl=http%3A%2F%2Fwww.hardwaresecrets.com%2Fimageview.php%253Fimage%253D39808&w=225&h=300&ei=ZIgOU4K_I6Ge0QHi1oCgBw&zoom=1&ved=0CO0BEIQcMDA&iact=rc&dur=859&page=5&start=38&ndsp=12
another nzxt product that has what i'm looking for...the youtube should start at the correct time
http://youtu.be/ltgSRg5iJEg
Also do you think it's worth having all 8 fans? Or should I just buy 2 front/2 top/leave bottom and side fans alone?
