Okay so I recently built my new computer and I am having a few problems. My card is EVGA GeForce GTX760 SuperClocked 2GB GDDR5 256bit and this card has two plug ins for power, one 6 pin connector and another 8 pin. The cables that came with the card were a 8 pin to dual 6 pin connector and a 6 pin to dual 3 pin molex connector. First of all I tried plugging the 8 pin connector in to my pcie cables from my power supply and when I boot up the computer I get a message on my monitor that says please power down and connect the graphics card's power cables in to the pcie cables. Even when they are both plugged in. So this leads me to believe that it is required that I use both cables that came with the card. The only problem with this is there are no 3 pin female molex cables from my power supply. Would 3 pin fit into 4 pin? Or do I need to buy an adapter, if so could someone recommend one to buy? Thanks.
