Hi. I'm going to have an H500M case with a H115i Platinum cooler at the top. I had intended on placing the fans under the radiator but unfortunately I just realized that because of the heatsink on the motherboard I will not be able to fit one fan under the radiator and will have to mount both fans above the radiator. I've watched a video of tests being done with radiator fans placed in all different positions and the results were the same for placing the fans under the radiator or above it. The guy also said that placing the fans above the radiator is much better for dust management as the dust will build up on the radiator and you can just blow it away easily rather than the dust getting caught in the fans.
What I want to know is will the hot air created by the GPU be exhausted properly this way? I'll have just the one rear exhaust fan and I'm afraid since the fans won't be placed below the radiator that it will cause too much heat build up inside the chassis.
