So I am putting together a build. I’m thinking on getting a Ryzen 3800X and RTX2070. My wattage should be around 550 according to pc part picker.. my only concern is that the CPU is near 100 watts before OC, and the psu shows the 3.3V and 5V rails start 100watts, will it work or do I need to find something with more wattage on those rails? (Also not 100% sure if those are even the rails for CPU power.. saw something online that said it is)
Picked the PSU off this Best Power Supplies 2019
Thanks
Thanks
