[SOLVED] Question about SMA connectors (for WiFi card upgrade)
okino
105
Hi everyone, would really appreciate a clarification on this haha.
Basically, I am confused because the information on the net says that RP-SMA will not work electronically with SMA connectors, even though it might fit mechanically -> https://www.spo-comm.de/en/blog/know-how/what-is-the-difference-between-sma-and-rp-sma
However, my mobo's manual says that the two connectors coming out of the back panel are regular SMA connectors, they have a pin sticking out so I am assuming it's an SMA male connector, here's my mobo's manual -> https://download.gigabyte.com/FileList/Manual/mb_manual_ga-z97n(h97n)-(wifi)_e.pdf
The reason for my confusion is that I had an old TP-Link router TL-WR1043ND V1, which according to its manual it has RP-SMA antennas -> https://static.tp-link.com/resources/document/TL-WR1043ND_V1_Datasheet.zip
I needed some antennas cuz the stock antenna wire broke, so I took out the antennas from this old router, and put them on the SMA male connector on my mobo, and my signal on 2.4 GHz turned to 99% from 40%(without any antennas).
Am I missing something here? I want to buy new antennas to support 5GHz but before I do so I want to confirm the SMA thing: Does RP-SMA male work on SMA male connectors fine? or is my mobo manual wrong and the sma connector is actually an RP-SMA female and that's why its working?
Thanks guys
EDIT: You can delete this thread, gigabyte were kind enough NOT to mention that their connectors are RP-SMA in the manual. I ended up figuring out it was RP-SMA when I found a gigabyte stock antenna page that mentioned they were RP-SMA https://www.amazon.ca/Gigabyte-2-4GHz-Antenna-Connectors-12CR5-1ANT02-11R/dp/B00W2TYU3A, those antennas came with the mobo and those were the ones that broke off.
I'd rather like to keep this thread alive, in order for the community to learn of how the issue was resolved. Thanks for making a follow up(albeit an edit) in the post to notify the problem was resolved.
To note, unless stated or shown physically, all antenna breakaways are RP-SMA. It's only on older motherboards by Asus where WiFi wasn't a common bundle on motherboard's where they used a much smaller WiFi breakaway. One name that comes to mind is the Asus Rampage V Extreme.
Have fun!
Have fun!
Have fun!
Wow, thanks for this info I was unaware of this, man I spent hours checking SMA to RPSMA converters for nothing haha. Now I understand most modern devices will have RP-SMA even if they refer to it in manuals as SMA or standard SMA. looking forward to getting a new wifi card!
