I'm getting some audio artifacting with my pc hooked up to my projector. Having friends over to game on it again Saturday. Last time we lost sound altogether at one point.
Someone mentioned to check what the output from my motherboard is to see that is it 48000 hz. Apparently that's kind of the standard. I did some research online and found that is correct and that sometimes a 41000 hz is used but that's cd quality. Anyway, I found where to change it on my pc and I wanted to post the options I have here to see what I should be using so that I'm not getting two different settings in case that's what is messing up my audio.
16bits 44100
16bits 48000
16bits 96000
16bits 192000
24bits 44100
24bits 48000
24bits 96000
24bits 192000
16bits 44100
16bits 48000
16bits 96000
16bits 192000
24bits 44100
24bits 48000
24bits 96000
24bits 192000
