Question about speed TROAD.
G
Guest
Guest
Archived from groups: alt.games.tombraider (More info?)
Hi,
I have a question about the speed of TROAD.
My pc is working with Windows XP, a Celeron CPU 2.00GHz and 512 MB RAM
Memory.
I first had only 256 MB RAM, and the game was almost in slowmotion
then, so I thought putting in another 256 MB RAM would help, but it
didn't.
Can anybody help me out here??
I have the game for a while now and I really would like to be able to
play it now 🙂)
But please, in simple terms if you please, my english isn't bad, but
technically will be a bit more difficult.
Thanks in advance.
Elly.
Elly wrote:
> Hi,
> Memory.
> didn't.
> play it now 🙂)
> Thanks in advance.
> Elly.
You have enough processor and memory, but don't state what video card or
chip you have. That will be problem anyway.
s
You're right, I forgot to mention those, sorry.
Videocard is NVidia GeForce FX 5200.
What do you mean by chip??
Elly.
>s
> Elly.
>> card or chip you have. That will be problem anyway.
>> s
The FX5200 is where your trouble is. Even though it's an Nvidia 'FX',
it's the low end of that series. FX5900 would be quite playable on your
system I think.
s
> Elly.
>> s
By chip I meant chipset, as some computers come with graphics chipsets
built onboard.
Not an expansion card.
s
Thanks, although I am not happy with that.
It means I will have to buy a new one, and I do not want to keep
asking my new bopyfriend for everything, which means I will have to
save up a bit first.
But thanks for helping me out here.
Elly.
>system I think.
>s
> Elly.
>> 'FX', it's the low end of that series. FX5900 would be quite
>> playable on your system I think.
>> s
Try turning off some features, like shadows, go to lower resolution.
These will help.
Wow, this is technical, hihi, I have no idea if I have that, but I
will try to find out.
Btw, would it help somewhat if I would update the videocardchip??
Elly.
>built onboard.
>s
> Elly.
>> chipsets built onboard.
>> s
You update videocardchip by new videocard :) You update videochip on
motherboard with new card or new motherboard. I'm not helping much 🙁
s
Okay, I will try that.
I do want a new videocard though someday, but for the time being I
will try these things, hope it helps a little 🙂
Thanks.
Elly.
>These will help.
Alright, I understand what you mean 🙂
For now I will just have to do with what I have, and when I can I will
buy a new videocard, thanks for helping me 🙂
Elly.
>s
