I am a bit confused here, Compu. You list the following temperature scale in the Core 2 Duo Tmperature Guide
Tcase/Tjunction
--70--/--85--85-- Shutdown
--65--/--80--80-- Throttle
--60--/--75--75-- Hot
--55--/--70--70-- Warm
--50--/--65--65-- N
--45--/--60--60-- O
--40--/--55--55-- R
--35--/--50--50-- M
--30--/--45--45-- A
--25--/--40--40-- L
--20--/--35--35-- Cold
So 50-deg Tcase is the highest normal temp. It also states that the idle to load delta is ~25. This means that Tcase at idle is 25-deg. That's not even warm...if my wife were in charge of the thermostat it would always be that warm in our apartment.
In fact, lets say it's summertime. We have no airconditioning, but it doesn't get too hot because we live right by the water. So let's say ambiant is 28-deg. Now assume Tcase is at least 2-deg warmer than ambiant, add another 25 degrees at load, and Tcase is at 55-deg...WARM. If were 32-deg ambiant , the processor would be HOT.
I'm guessing maybe the idle to load delta changes with the cpu frequency? I guess this is something I should have noticed or looked into already. 25-deg is max delta with a hefty overclock. And idle to load delta is significantly less at stock speeds?
Tcase/Tjunction
--50--/--65--65-- N
--45--/--60--60-- O
--40--/--55--55-- R
--35--/--50--50-- M
--30--/--45--45-- A
--25--/--40--40-- L
