Hi there!
I have just purchased the Corsair Hydro Series h115i and I have some questions about the pump and fan connections. This is my first build, and my first AIO so bear with me please.
According to the manual I am supposed to connect a 3-pin connector to the CPU_header and then connect the fans' 4-pin connectors to two female connectors. This essentially means that the two fans are only connected to the MOBO with the 3-pin connector in the CPU_header.
As far as I understand, to control a fan with PWM you need to put it in a 4-pin connector on the MOBO. So are the fans not controllable with PWM?
The manual also tells me to connect a usb to the pump to control everything with Corsair Link. I did this and tried to control it with Corsair Link, but that program seems so shitty! Or am I using it wrong?
I hope you can decipher what I am asking here!
Thanks for any help you guys can supply!
