I'm currently using 4 sticks (512 each) of 533-ddr2 in my M2N-E mobo for a total of 2gb (obviously hah). It's value ram so the timings are 4-4-4-12-2T and it is running in dual channel since it has 2 pairs. Now my brother has 2x1GB sticks in his almost exact same build that I have and they are 667-ddr2 and also value so 5-5-5-15-2T.
My main question was assuming we have the same timings and speed on the ram would there be any difference between running the 2GB with 4 slots or with 2? Also any discussion on the difference you will see between 533 and 667 setups I described would be welcome.
I'm probably going to bench the 2 systems also with passmark which I should have done already but any other recommendation on ram test programs would be great.
Thanks.
Thanks.
