Question Question about where to insert RGB fans
HerEyeSin
209
so I will be getting thermaltake RGB fans I think. I also plan on syncing them with Asus aura. My question is how hard is it to change from Asus aura back to the actual thermal take RGB software? Do I have to change where certain wires go? Lol I’m new to this
I hope I'm understanding your question correctly.
If you are asking "How do I go from using Asus Aura Sync to the ThermalTake RGB software?" then It's pretty simple really. Just uninstall Aura and then install the ThermalTake software.
If you are asking something else, please clarify.
That’s exactly it thanks. I just wasn’t sure if I had to change where some cables go. Didn’t know it was as simple as that. But then another question comes to mind. Is it possible to use ASUS aura for MOBO and graphics card while using thermaltake software for fans
I can't think of a reason it wouldn't, unless they both have some files that are the same and then both programs try to use the same file which will cause it not to run at all in which case, just reinstall them and make sure to install them in different locations. good luck!
