Greetings. i had a question about the Intel Core 2 Duo E8400 Wolfdale 3.0GHz 6MB L2 Cache LGA 775 65W Dual-Core Processor and its overclocking capabilities.
I know that in order to overclock an intel cpu, you have to increase the Bus Speed and choose your Clock Ratio and also finally choose your System Memory Multiplier which determines how fast the memory runs.
for example, right now i have a Pentium 4 cedar mill overclocked to 4.5 ghz, and my corsair xms2 series ram running at thier maximum of 800 mhz. My motherboard, a GIGABYTE ga-g31m-s2l supports to the maximum an 800 mhz RAM situation, although it also claims to support a 1333 mhz FSB? i thought that was the speed at which the processor communicates with the RAM, why would a motherboard support a faster FSB frequency than the RAM frequency?
here is what i am using in the BIOS:
Clock Ratio: 15x
Bus Speed: 300 Mhz
System Memory Multiplier: 2.66 (availabe options are 2.66, 3.33, or 4)
now, i would love to push the E8400 over 4.0 ghz like so many others have done but i need to know the Clock Ratio, Bus Speed and System Memory Multiplier options that are available with the E8400. My motherboard says in its manual that the System Memory Multiplier options available are dependent on the CPU FSB settings, so if i put another CPU in the socket will the available options change? or is that not true and the 2.66,3.33,4 options only what im going to get?
would the following situation be possible with the Wolfdale and my GIGABYTE ga-g31m-s2l motherboard:
Clock Ratio: 8
bus speed: 500
System Memory Multiplier: 1.6
thus giving both cores a frequency of 4 ghz? what are the available options that are shipped with the E8400? i should note, if i ever try to push the ram over 800 mhz then i get almost an instant crash at the windows xp desktop. also, what would happen if my Rated FSB were to go over 1333? would my computer also crash because my motherboard can only go as high as a 1333 FSB? i have seen alot of success stories of people overclocking with the bus of the E8400 into the 450 MHZ range, so surely if it is quad pumped that would be a FSB of 1800 MHZ... i have not seen motherboard go that high, or maybe it doesnt matter as much?
i guess my biggest problem is the System Memory Multiplier because i cant go over 800 mhz for the RAM, although i think its my motherboard that is picky about that, not the RAM itself.
Clock Ratio: 15x
Bus Speed: 300 Mhz
Clock Ratio: 8
bus speed: 500
