Question Question concerning an IPS LED LCD display ?
cloudff7ps1
440
If I keep a portable electronic device that uses an IPS LED LCD display unused for many years, will the display have problems? I store and protect it in boxes to protect it from light and extreme temperatures and dust.
If the display IPS LED LCD is not energized frequently and is stored for many years without use, the liquid crystals will go to sleep and will not respond correctly. Will it generate problems with the pixels and permanent image retention?
If you store an any IPS LED LCD panel without using it for a long time (many years), will the pixels develop dead and stuck pixels? Can liquid crystals settle over time, leading to slow response times or "stuckness", where they may not change state correctly when turned on after years of inactivity? Do LEDs and backlights die or lose efficiency?
My devices are handheld consoles Powkiddy Q80 and R36S
My maximum long-term storage temperature is 36C with humidity 58-68%, do LEDs have a maximum temperature they can withstand before they start to degrade and lose efficiency and brightness? Is the backlight associated with LED degradation?
Does LCD (liquid crystal) have a maximum storage temperature it can withstand before it degrades? LCD is organic, so it degrades quickly?
In the maybe published spec sheets for these things, what does it say about storage temps?
But further, what does it matter?
If your temp of "36C" is too much, what might you do?
What is the good temperature range for long-term storage of TFT LCD IPS LED backlight displays? Do manufacturers have a range or does it vary greatly between manufacturers? And what is the maximum humidity without presenting risks?
I do not know the models and manufacturers of the R36S and Powkiddy Q80 displays? this consoles uses 3.5" IPS
Have you ever seen the LCD slow down and become complacent after years of storage? Has the problem been resolved or is it permanent on the display?
It is impossible to say.
Not all panels are made the same.
No.
