these are the same leads as on my earlier build with an ASUS mobo, so i assume this is pretty standard configuration. Difference, my earlier build, a single plug covered all 9 pins
question on assembling the computer. I'm really electrically "literate", but connecting one of the headers, as asrock refers to it, the manual leaves a little to be desired, that and the leads from the case are not on one plastic plug but a bunch of small ones
the lead or plug for the reset button, is a two socket plug with female receptacles, and it can actually mount 4 different ways - see photo below, with the sockets in the plug oriented north/south and the lettering on the plug body facing to the east or to the west
Then again, with the sockets oriented east/west, and with the lettering on the plug oriented north or oriented south
i have a suspicion it probably doesn't make a difference as this is nothing more than a jumper closing the circuit for the reset, but just wanted to make sure
thanks in advance
thanks in advance
