So i built my system back in 2017 with a 1080ti and 2700x and x470 motherboard and so forth back in 2017.. I spent $1100 on the watercooling setup just by itself, this includes the 11 Thermaltake Ring plus fans, and the two EK 360mm radiators, connectors, tubing, coolant, the EK reservoir and pump, and the secondary reservoir. Three EK cpu waterblock and the 1080ti waterblock.
Why did i spend so much on cooling? Well, ive been watercooling for 25 years now, back when some of you probably werent born HAHA, back then we used pond pumps, car heatercores and had waterblock made by dangerden.com.. I used that stuff for well 22 years.. recycling the waterblock all the way from my Athlon xp to my Intel e8700 cpu, i just modded the mounting system... So for 22 years i didnt spend a dime on cooling anything.. So i think i deserved the whole 1100$ upgrade.
Anyway, its been 5 years, 3 years ago i got a x570 and 3800x, i just upgraded the cpu to a 5800x 3d, and i sold my 1080ti and got a 6900xt with waterblock for $600. The way i have my setup is i have one 360mm in front of the case "a thermaltake view 71 case" with 6 of the thermaltake ring fans on it, 3 pushing in, 3 pulling into the case. Then i have this loop going to the reservoirs/pump, and it goes into the cpu, then from the cpu directly above the 2nd 360mm radiator, with 5 fans, 2 140mm fans, and 3 RING fans, this setup is actually pulling air from on top of the case down into the case. So both radiators are blowing into the case, then i have 2 ring fans on the bottom of the case also blowing in, and then 1 140mm fan blowing out the back top of the case.
The reason i did both radiators blowing in, versus the front blowing in, and top blowing out. Was because i figured that the top radiator blowing out would just be sucking in the hot air in the case, and hot air from the first radiator right into itself. Kind defeating the point of cold air on the radiators. This also creates a positive air pressure in the case, with all these fans blowing in, and 1 exhaust fan blowing out the back. However with the 6900xt and 5800x3d.. the heat the both put off is immense compared to the 1080ti and 3800x. I also kept my fan profile to quiet so they didnt really increase to max speeds.. But this 5800x 3d gets to 80-90c after playing games for 2 hours in a closed room like this. I opened the case and it was full of really warm air. I dont think i have enough exhaust fans, and the radiators blowing hot air inside the case seems excessive with 1 exhaust fan.
Now this case is a "open" case to where all the glass surrounding it is extended out by 1/2 an inch or so.. So air is never really "trapped" in the system. I decided to change my fan XMP profile and now the fans kick on 100% at 70c, and doing this, my cpu temp dropped from 80-90 to 68-73c when gaming, and the case cooled down quiet a bit too due to the positive pressure and the open glass panels.. But my question is this.. should i keep it like this ? Or should i also change the top radiator fans to blowing air out..., again the reason i didnt do this was because that will just mean the fans are sucking the hot case air and air from the first radiator.. right into itself.. basically negating the cooling effect the first radiator did.. seems kinda pointless to blow hot air on a radiator doesnt it ? Yes i know hot air rises, but this is air thats moving.. not sitting, so that has no role here.
