[SOLVED] Question i5 6500 - GTX 970 system upgrade help.
arjenrobbennn
7
Cpu : i5 6500
graphic card : gtx 970
Motherboard : h-170 pro gaming asus
Ram : 8gb 2133mhz
PSU: Nagas AO750 80+ Bronze 12Cm Power Supply 750
I want to upgrade my pc. What do you prefer to upgrade? budget 250-300$
With that budget i would suggest a 450/470 AM4 Board and a Ryzen, and a another, SAME (!), Ram.
For gaming Intels are better yes, but with that budget you cant even get a new Cpu from Intel :b
