Question Question mATX vs ATX mobo
Sep 15, 2023
50
5
35
Hello,
Im considering to buy a mATX motherboard, but my case can also handle ATX, however I have read somewhere that ATX only offers a SLI and bunch of more PCIe slots... But since I dont intend on using SLI, am I better with with mATX motherboard or am I missing someothing what other advantages does ATX offer?
Additionally can a lower end mATX mobo with LGA1700 socket run a 13gen CPU such as Intel Core i9-13900K?
(for motherboard info, this one cought my eye MSI PRO B660M-P WIFI DDR4)
Thanks a lot in advance! :)
On ATX board you'll have more space for additional features:
more M.2 slots,​
more PCIE slots,​
more fan headers,​
more aRGB/RGB headers,​
more USB2/USB3 headers,​
beefier heat-sinks.​
SLI hasn't been a consideration for a very long time. It has been essentially abandoned.
In fact - most modern ATX boards do not support SLI.
Hello,
You can use either just make sure it has the features you need.
The board your looking at is in no way made to be used with a 13900k the power delivery on that board is very poor.
Reactions: WutisDat
more M.2 slots,​
more PCIE slots,​
more fan headers,​
Hey man, thanks a lot for your answer. Could you please tell me how would I know for the next time, which board have sufficient so called "power delivery" or how do I figure that out? Thanks again!
Additionally, would you consider the AMD Ryzen 9 5950X better than the i9-13900k. I have read somewhere the i9 takes a lot of heat... is that true?
more M.2 slots,​
more PCIE slots,​
more fan headers,​
Thanks a lot for the insight mate! All in all, I dont rly need much of the fancy stuff, so I guess the mATX could be good to go. But how about mini ITX , could any of these micro mobos sustain i9-13900 core, considering I dont care about overclocking? Thanks again :)
You can Google the motherboard model and power phase and see it for that one at least a 14+1
For your other question it depends on what the PC will be used for..
For gaming a 12700, 13700, 5800x3d would do fine.
What would you say is the best lower end M-ITX, that can easily handle i9-13900K?
Does the part picker help in this or do I need to check some additional stuff like that power phase thingy...? I dont even know what that is lol... im such a noob >.<
A Mitx motherboard in a ATX case looks dinky.
Yeah... I was just thinking to maybe place it in different case later in the future if I need some portability. But thats just a random idea, not sure about it yet.
The one you sent seems pretty good tho it says its powerphase is 12+1... is that gonna be enough to run the i9-13900K?
