Question of GTX 770 SLI pcie 3.0 speed
It probably has to do with how many PCI-e lanes your motherboard/chipset can support. For example most Intel chipsets (with the exception of X79) can only support 16 PCI-e 2.0/3.0 lanes. So when you have two cards plugged in, they have to run in x8/x8 since running in x16/x16 would require more lanes than the chipset can support.
Don't worry about this, though. In practice you will never saturate PCI-e 3.0 x8 bandwidth with dual-770 SLI.
Thank you. My mother board ASUS Maximus V formular, support Nvidia 2 way SLI and AMD 3 way cross fire. Does this board do not have enough lane for 2 x pcei 3.0 ?
Thanks
Like aznricepuff said, there are boards that can run at dual x16. But the majority of boards (including yours) run at dual x8 with two cards, and x8/x4/x4 with three cards. Four cards is stupid, and there is no four-way SLI unless you use two GTX 690 which contain two GPU running in SLI on a single card.
Hi GTX TITAN has 4 way SLI
http://www.youtube.com/watch?v=3vCrblKzKaM
