Question regarding Calculating Volume in Java
Randi Poling
258
27
18,840
THee is a lab I am working on for Java Programming and I am kind of in a pinch. I have got everything else down for this lab except for the following:
Volume of a pentagon prism = 5(𝑝𝑒𝑛𝑡𝑎𝑔𝑜𝑛𝑆𝑖𝑑𝑒2 )/ 4(tan( 𝜋 5 )) x prismHeight
Volume of a regular pentagon pyramid = 1/24 (5 + √5) 𝑝𝑒𝑛𝑡𝑎𝑔𝑜𝑛𝑆𝑖𝑑𝑒 3
Any hints on as to write it to calculate these out? Or any sites that would have some good tutorials on doing so?
hint... search for Volume of a pentagon prism java in google
https://www.geeksforgeeks.org/program-to-find-volume-and-surface-area-of-pentagonal-prism/
Code:
// Java program to find
// surface area and volume of the
// Pentagonal Prism
import java.util.*;
class solution
// function for surface area
static float surfaceArea(float a, float b, float h)
    return 5 * a * b + 5 * b * h;
// function for VOlume
static float volume(float b, float h)
    return (5 * b * h) / 2;
// Driver function
public static void main(String arr[])
    float a = 5;
    float b = 3;
    float h = 7;
    System.out.println( "surface area= "+surfaceArea(a, b, h)+", ");
    System.out.println("volume= "+volume(b, h));
[/code[
there it is in several programming languages
perform a similar google search for the other thing you need. use your internet resources.
