Question Question regarding LatencyMon issue, OMEN 40L
Jun 13, 2025
Has anyone ran into this issue and can help me with troubleshooting it? I am using LatencyMon to generate this
"Our system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates."
Here is some of my system info
OS version: Windows 11, 10.0, version 2009, build: 26100 (x64)
Hardware: OMEN by HP 40L Gaming Desktop GT21-1xxx, HP
BIOS: F.18
CPU: AuthenticAMD AMD Ryzen 7 7700 8-Core Processor
Logical processors: 16
Processor groups: 1
Processor group size: 16
RAM: 15501 MB total
Let me know if I can provide anything else ,any help or guidance would be great, thank you!
BIOS: F.18
Processor groups: 1
RAM: 15501 MB total
Here is the rest of the details
CPU SPEED
_________________________________________________________________________________________________________
Reported CPU speed (WMI): 3801 MHz
Reported CPU speed (registry): 3793 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 4582.60
Average measured interrupt to process latency (µs): 14.422074
Highest measured interrupt to DPC latency (µs): 4576.60
Average measured interrupt to DPC latency (µs): 7.686155
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 99.813868
Driver with highest ISR routine execution time: HDAudBus.sys - High Definition Audio Bus Driver, Microsoft Corporation
Highest reported total ISR routine time (%): 0.010645
Driver with highest ISR total time: HDAudBus.sys - High Definition Audio Bus Driver, Microsoft Corporation
Total time spent in ISRs (%) 0.011199
ISR count (execution time <250 µs): 182168
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-1000 µs): 0
ISR count (execution time 1000-2000 µs): 0
ISR count (execution time 2000-4000 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 3876.851569
Driver with highest DPC routine execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 576.52 , NVIDIA Corporation
Highest reported total DPC routine time (%): 0.131391
Driver with highest DPC total execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Total time spent in DPCs (%) 0.297103
DPC count (execution time <250 µs): 2543464
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-10000 µs): 166
DPC count (execution time 1000-2000 µs): 0
DPC count (execution time 2000-4000 µs): 40
DPC count (execution time >=4000 µs): 0
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: system
Total number of hard pagefaults 80300
Hard pagefault count of hardest hit process: 34269
Number of processes hit: 107
PER CPU DATA
CPU 0 Interrupt cycle time (s): 54.228055
CPU 0 ISR highest execution time (µs): 99.813868
CPU 0 ISR total execution time (s): 0.915680
CPU 0 ISR count: 182048
CPU 0 DPC highest execution time (µs): 3876.851569
CPU 0 DPC total execution time (s): 23.242502
CPU 0 DPC count: 1971463
CPU 1 Interrupt cycle time (s): 1.601561
CPU 1 ISR highest execution time (µs): 17.472186
CPU 1 ISR total execution time (s): 0.000462
CPU 1 ISR count: 120
CPU 1 DPC highest execution time (µs): 137.363037
CPU 1 DPC total execution time (s): 0.039252
CPU 1 DPC count: 19848
CPU 2 Interrupt cycle time (s): 3.206482
CPU 2 ISR highest execution time (µs): 0.0
CPU 2 ISR total execution time (s): 0.0
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 170.113367
CPU 2 DPC total execution time (s): 0.145663
CPU 2 DPC count: 90576
CPU 3 Interrupt cycle time (s): 2.603116
CPU 3 ISR highest execution time (µs): 0.0
CPU 3 ISR total execution time (s): 0.0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 3387.480095
CPU 3 DPC total execution time (s): 0.078682
CPU 3 DPC count: 50772
CPU 4 Interrupt cycle time (s): 1.565907
CPU 4 ISR highest execution time (µs): 0.0
CPU 4 ISR total execution time (s): 0.0
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 79.466385
CPU 4 DPC total execution time (s): 0.025785
CPU 4 DPC count: 16991
CPU 5 Interrupt cycle time (s): 1.415819
CPU 5 ISR highest execution time (µs): 0.0
CPU 5 ISR total execution time (s): 0.0
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 54.350119
CPU 5 DPC total execution time (s): 0.020644
CPU 5 DPC count: 11394
CPU 6 Interrupt cycle time (s): 2.472555
CPU 6 ISR highest execution time (µs): 0.0
CPU 6 ISR total execution time (s): 0.0
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 187.184814
CPU 6 DPC total execution time (s): 0.085603
CPU 6 DPC count: 63330
CPU 7 Interrupt cycle time (s): 1.912066
CPU 7 ISR highest execution time (µs): 0.0
CPU 7 ISR total execution time (s): 0.0
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 3434.526760
CPU 7 DPC total execution time (s): 0.067665
CPU 7 DPC count: 38747
CPU 8 Interrupt cycle time (s): 1.826996
CPU 8 ISR highest execution time (µs): 0.0
CPU 8 ISR total execution time (s): 0.0
CPU 8 ISR count: 0
CPU 8 DPC highest execution time (µs): 3441.018719
CPU 8 DPC total execution time (s): 0.054955
CPU 8 DPC count: 39748
CPU 9 Interrupt cycle time (s): 1.872274
CPU 9 ISR highest execution time (µs): 0.0
CPU 9 ISR total execution time (s): 0.0
CPU 9 ISR count: 0
CPU 9 DPC highest execution time (µs): 89.314527
CPU 9 DPC total execution time (s): 0.045592
CPU 9 DPC count: 25202
CPU 10 Interrupt cycle time (s): 7.176299
CPU 10 ISR highest execution time (µs): 0.0
CPU 10 ISR total execution time (s): 0.0
CPU 10 ISR count: 0
CPU 10 DPC highest execution time (µs): 3465.674137
CPU 10 DPC total execution time (s): 0.253880
CPU 10 DPC count: 89034
CPU 11 Interrupt cycle time (s): 2.457296
CPU 11 ISR highest execution time (µs): 0.0
CPU 11 ISR total execution time (s): 0.0
CPU 11 ISR count: 0
CPU 11 DPC highest execution time (µs): 99.182705
CPU 11 DPC total execution time (s): 0.084158
CPU 11 DPC count: 46358
CPU 12 Interrupt cycle time (s): 1.787303
CPU 12 ISR highest execution time (µs): 0.0
CPU 12 ISR total execution time (s): 0.0
CPU 12 ISR count: 0
CPU 12 DPC highest execution time (µs): 49.070393
CPU 12 DPC total execution time (s): 0.019599
CPU 12 DPC count: 12511
CPU 13 Interrupt cycle time (s): 1.090786
CPU 13 ISR highest execution time (µs): 0.0
CPU 13 ISR total execution time (s): 0.0
CPU 13 ISR count: 0
CPU 13 DPC highest execution time (µs): 67.774848
CPU 13 DPC total execution time (s): 0.017831
CPU 13 DPC count: 9066
CPU 14 Interrupt cycle time (s): 1.307962
CPU 14 ISR highest execution time (µs): 0.0
CPU 14 ISR total execution time (s): 0.0
CPU 14 ISR count: 0
CPU 14 DPC highest execution time (µs): 63.767466
CPU 14 DPC total execution time (s): 0.052370
CPU 14 DPC count: 28757
CPU 15 Interrupt cycle time (s): 1.087737
CPU 15 ISR highest execution time (µs): 0.0
CPU 15 ISR total execution time (s): 0.0
CPU 15 ISR count: 0
CPU 15 DPC highest execution time (µs): 110.032692
CPU 15 DPC total execution time (s): 0.069618
CPU 15 DPC count: 29873
