Question Question Regarding Motherboard ATX Power connector
Apr 4, 2020
https://pcpartpicker.com/user/oofyalex/saved/#view=WsmW3C “The Asus TUF GAMING X570-PLUS (WI-FI) ATX AM4 Motherboard has an additional 4-pin ATX power connector but the Corsair RMx (2018) 650 W 80+ Gold Certified Fully Modular ATX Power Supply does not. This connector is used to supply additional 12V current to the motherboard. While the system will likely still run without it, higher current demands such as extreme overclocking or large video card current draws may require it.” Should I be worried about it? Other than that, what should I change? my budgets around 1600 with the monitor.
That information is completely incorrect.
The Corsair TRMx 650 has TWO 4 Pin ATX power connectors on it. Its in a 4+4 configuration, so you can use both together or just 1.
Its on the Spec Page for the PSU:
https://www.corsair.com/us/en/Categ...ply-Units-Advanced/RMx-Series/p/CP-9020178-NA
I hate those notes on PCPP they are often wrong.
Side Note: Next time you post a question here, try making the question title a little more descriptive than "Question". The only reason I saw this thread is because I am a moderator and I had to approve it.
