Question regarding SLI, exact duplicate required?
Fritjoff
Good day,
Forgive my ignorance on the issue, but I am in the dark on this matter regarding SLI. I own a EVGA 660 Ti 3GB. To be exact I have this http://www.newegg.com/Product/Product.aspx?Item=N82E16814130812 .
I am having a tough time trying to fine the exact model, 03G-P4-3663-KR, out there even from Ebay, Amazon and the like. Though, I have found the following model 03G-P4-3661-KR, on Amazon. Or http://www.newegg.com/Product/Product.aspx?Item=N82E16814130812 .
Question being, can I get these two cards to play nicely together in SLI? Would I have to clock down the other card to match the other? Or is not feasible? Any input would be greatly appreciated?
Thanks.
Exact Same is always perfect, but typically for SLI you can get different model numbers, etc.. as long as:
1. Same RAM Size
2. Same Card type: ie: both 660 Ti
3. Same Clock Speed -- This is desired, if they are different, then it will run at the slowest cards rate
