Questions about choosing a monitor for gaming
FknPitsy
5
Hey all, I'm looking at getting a new monitor for the PC I'm going to build and I'm reading a few conflicting things. Just looking for a little clarification, or help.
A few people have said they like the IPS panels for their better colours, so I was swinging toward getting one of those. They typically have longer response times though and some people have said that 2ms is a must, where others say 5ms is fine.
Guess I'm asking whether it's worth me buying the IPS with the slower response, or go for a TA for less and get the quicker response with worse colours.
The IPS panels with <5ms are a little out of my price-range, unfortunately.
Thanks
It will be very very minimal and better colors will look nicer. The only time i'd recommend a tn panel is if you play only cs go comp and want the little boost in your gameplay.
Thanks for the response (no pun intended).
So the monitor I was looking at is a 5ms, as opposed to the 2ms of the other panels. In your opinion then, that response time won't even be noticeable?
