Hi, I just posted a thread about what CPU Cooling to get acording to my Rig.
-AMD FX6350
-16GB DDR3 HyperX Fury (4x4)
-Gigabyte 970A-DS3P
-Xigmatek Prime SD1484
-AMD Radeon R9 280X 3GB GDDR5
-Thermaltake GTS10 Black Case
So basically I changed the cooling system because the AMD stock one was way too loud, but it did the job of doing cooling pretty good 15-20ºC Idle / 45-50ºC Gaming.
So after installing the new cooler (installation was such a pain in the ass) I was able to see some weird stuff.
Note: In order to install the cooler I had to remove the back 12x12 fan on the case, which I thought was not going to be useful. (I never put it back so this is one point to have in mind)
Here are the temperatures screenshot according to some Prime95 Stress Test and Idle temps (with a 27ºC temperature on the room):
FPU Stress:
Heat Test:
Lots of RAM Tested:
Idle
So as you can see we have 60ºC temps at full load on Prime95 Tests and about 25ºC on idle temperatures, plus the case getting hot on the outside, which with the other cooler did not happen.
So you guys think this temperatures are correct?
Do you see anything wrong?
Shouldn't that cooler cool A LOT better than the stock one?
At least it does not make a lot of noise when gaming or at full load which was my main goal.
PS: I just realized something which I think it's very important here...
Look at this image:
http://images.tweaktown.com/content/4/3/4388_99_xigmatek_prime_sd1484_hdt_cpu_cooler_review_full.jpg
This is the correct way to install the cooler right? I mean every single image I see it is installed in that position with the fans on the "sides" one looking at the RAMs and the other looking at the backplate connections.
For some reason...mine is installed the other way arround or upside down, yes...
My cooler is not vertical, it is installed horizontal and one of the fans is looking at the top of the case and the other looking at the external cards connected to my PCI connections.
I think this might be some of the issues I'm having with heating, could that be possible or it's the same thing? Plus remember I removed the back 12x12 fan on the case...So what should I do? 🙁
-AMD FX6350
-Gigabyte 970A-DS3P
FPU Stress:
Heat Test:
Lots of RAM Tested:
Idle
Look at this image:
