Questions about fans and cooling
Oleonius
448
Hi,
I have some random questions about cooling and fans:
- Do you know if a Corsair H100i will fit in the Fractal Design Define XL R2 case ? If yes, will it be possible to do a push/pull configuration ?
- What fans do you recommend to replace the stock 140mm fans of the Define XL and the stock 120mm fans of the H100i ?
I was looking on Newegg.ca and I and I found these fans that seems to have good feedbacks.
Aerocool Shark 140 (also avaible in 120mm):
http://www.newegg.ca/Product/Product.aspx?Item=N82E16835129059&IsVirtualParent=1
Prolimatech Blue Vortex 140 (also avaible in 120mm):
http://www.newegg.ca/Product/Product.aspx?Item=N82E16835242011
Bitfenix Spectre Pro 140 (also avaible in 120mm):
http://www.newegg.ca/Product/Product.aspx?Item=N82E16835345069
Cougar Vortex HDB 140 (also avaible in 120mm):
http://www.newegg.ca/Product/Product.aspx?Item=N82E16835553007
The H100i should be fine up top but not sure on the P/P, you can P/P with an Arc Midi R2 though.
Have not kept up much with fans, if your looking for 3pin fans the Noctua makes great fans now, but a lot of people say the GT-15 is the very best 120mm radiator fan you can buy at in the $20 range for the noise and smooth rpm curve, 800-1800rpm and good pressure.
http://www.frozencpu.com/products/10323/fan-674/Scythe_Gentle_Typhoon_120mm_x_25mm_Fan_-_1850_RPM_D1225C12B5AP-15_Hot_Item_.html?tl=g36c15s60
I would tend to favor the Thermalright X-Silent for low speed , for high speeds, the Aerocool Shark in 140mm.
