I have seen many pages of advice on placing fans in Corsair 300R cases with water cooling. However, I am seeking assistance on an air-cooled configuration. I would like a slightly positive air pressure and I will place dust screens wherever possible.
1. My case's main heat sources are:
- An overclocked i7-9700K (cooled by a Noctua NH-D15 with its two stock fans)
- 2X16GB 3333 MHz DDR4 sticks
- An EVGA 1060 (This build is for running Lightroom, not for gaming, and this GPU is reported to be sufficient for that purpose. It may still need additional cooling, IMO.)
- 3 SSDs and 2 HDD
- A Gigabyte Z390 Aorus Ultimate motherboard
- A Corsair RM750X PSU
2. The arrangement of the key components are (must be) as follows:
- Mobo edge (next to RAM) will be about 2" down from the inside top of case. It is also close to the inside of the case rear
- 150mm exhaust fan of Noctua air cooler goes right over the top of at least some RAM (with my mobo choice, there should be 5mm of clearance with low-profile memory, say the wizards in Austria) and ends roughly 4" down from the inside top of case
- CPU is, of course, about centered on NH-D15
- PSU is in its usual place, at bottom of case
3. 300R case's factory-provided fan holes are:
- Two side-by-side in the top, one nearly right above the exhaust fan of NH-15
- One fan hole in the back of case, a little down from case top
- Two fan holes in the front of case, toward its bottom
4. Additional venting includes:
- Vent holes, possibly for fans, in the case side cover. (These can be covered with dust filters or small fans. They can be elegantly eliminated with a solid case cover. What is best for my cooling?)
- Small side vents in the case front and rear.
- Ventilation for PSU.
- Misc.
I have initial plans to use exhaust fans blowing out on one of the top holes (a few inches from my Noctua NH-D15's output) and on the top-rear hole. At least one of the fan holes in the front of the case should likely blow in air. Other than that, I am not sure where to start in fan sizing and placement.
- 3 SSDs and 2 HDD
- Misc.
