I want to use RAID 1 on a new Dell XPS PC using two 2 TB, M.2, PCIe NVMe, SSD drives and Intel RST. This will be a new PC with the OS already installed on the primary SSD drive and the other 2 TB drive will be empty. Creating a RAID 1 drive will be relatively easy to do since all that basically needs to be done is to set up install the IRST software and enable RAID. The primary SSD drive should then automatically be cloned to the spare drive
I've been reading about people having problems with their RAID when they need to replace the CMOS battery. The RAID breaks and all of the data is lost on both SSD drives. Does that really only happen on a RAID 0 configuration and not on RAID 1 configurations? Will a RAID 1 be OK other than the fact that the RAID is corrupted? Basically, the data still exists on both drives and the PC can still boot up, but the RAID is broken and needs to be rebuilt?
What if I were to do a Ctrl-I at boot and break the RAID 1 prior to replacing the CMOS battery? Basically, that would make 2 identical drives, but they would no longer be part of the RAID? Would that allow me to boot from the primary drive after changing the battery, and then turn RAID back on and have it recreate the RAID using the primary drive as the master to duplicate onto the second drive?
Thanks for any assistance anyone may provide!!
