questions about the Swiftech H320 X2 Prestige 3x120 mm Drive X2 Prestige AIO CPU Cooler
Nazy
49
alright i am looking to upgrade my aio on my computer and i was wondering if the Swiftech H320 X2 Prestige 3x120 mm Drive X2 Prestige AIO CPU Cooler was able to be expanded with a video card block and a extra rad and maybe a pump to cope with the extra rad and block and since it has the good fittings i just wanted to ask and see if it is expandable before i go and upgrade.
That one pump is enough to add a full cover GPU block, a 240mm radiator and then some run of tubings. One of the selling points is that it's competing against the closed loop AIO coolers though the added advantage is that the Swiftech unit is expandable and the add on parts can be bought from their store to have a full Swiftech outfitted loop.
Mind you, you'll be voiding warranty as you would with any AIO but the difference is that with available aftermarket G1/4" ports and fittings, interchangeable components as well as add on features, you're not loosing out on anything. You may also want to read through the watercooling sticky(located in my sig) to get a deeper understanding of watercooling as you will eventually foray into that...
Mind you, you'll be voiding warranty as you would with any AIO but the difference is that with available aftermarket G1/4" ports and fittings, interchangeable components as well as add on features, you're not loosing out on anything. You may also want to read through the watercooling sticky(located in my sig) to get a deeper understanding of watercooling as you will eventually foray into that territory.
