I purchased a WiFi Extender (Wavlink)
https://www.amazon.ca/dp/B0778PM5GR/ref=pe_3034960_233709270_TE_item
It seems to be working to get a signal to my Backup Generator located about 65 feet from my Wireless ZTE Router and about 30 feet from the Extender.
The generator has a built-in WiFi module.
The signal that the generator reports each day is approx -68dB.
I downloaded and installed the Netgear WiFi Analytics App and it sees 2 Connections (my Rogers wireless router RogersD2D3) and the Extender (RogersD2D3_EXT).
The signal strength at the router is Excellent (between 0dB and -25dB).
The signal strength next to the Extender is -52dB.
The Extender has 3 LEDs indicating signal strength and all 3 are lit.
I basically want to know if this thing is working as it should.
My Dell Inspiron laptop is connected to the Wireless router . If I sit next to the Extender and ask it to connect to the Extender, it can't. Am I understanding how this is supposed to work wrong?
Here is my question....should the signal strength next to the Extender be similar to the signal strength next to the Wireless Router if I have it set to Repeater Mode?
Changed the above sentence - I mentioned Extender twice when the second should have been Wireless router. duh!
To put it another way, should the signal strength 6 feet from the Extender be the same as it is 6 feet from the Wireless Router?
So let's concentrate on that one last question.
If more information is needed please let me know.
Thanks
Doug
Thanks
Doug
