I have an Ryzen 5 2600x, Asus Rog Strix X470. I am using the AMD stock cooler with two front of the case fans and one rear exit. The case I have is the Phantoeks P300S.
When i have the fans set as auto, while windows 10 is in idle the temp can flux from 40C to even 53 or 55C. Then the fan randomly kicks in and sounds louder.
I tried setting all my fans on full speed in BIOS which maintains 22C but i dont think I should have them set to full. I also don't over clock ever.
I was thinking of upgrading to the Corsair 540 case and getting either Noctua NH-D15 or a Corsair cooler.
Do you think both upgrades would help and what speed should case fans and cpu be set as?
Also will air or liquid cooling help a ton? I want my temperature to be very low.
