Questions on Corsair Crystal 570X RGB case
drjackool
285
Hi
Already i have CM Storm Trooper windowed case.
My question is the Corsair Crystal 570 case has enough value to buy it?
The glass material is real glass or is plastic?
Also my CPU cooler is Noctua D-14, can use it?
How is case cleaning? is it easy? dusty?
The corsair crystal 570x is undoubtedly a high quality case. The glass is real tempered glass.
Max CPU cooler height is 170mm so your CPU cooler will fit.
I do not personally own this case so I cannot speak too much about cleaning it, but it is a large, open case with thumb screws so it should be pretty easy.
As far as value over a CM storm trooper, that would depend on personal taste.
I would definitely take the 570x over a CM storm trooper.
