Hey guys,
So I've performed my first overclock, and it's a relatively safe one at the moment. System:
z77 extreme4
gtx 670 ftw sig 2
i5 3570k
hyper 212 evo
550w psu
16gb ram
Short and Sweet:
I ran prime95 tests and was getting temperatures around 90-93 degrees on some of the cores when set to 4.3 ghz. Seemed high, but after a cleaning and reapplication of thermal compound it was the same results.
So I dropped it to 4.2ghz and it tested fine after an hour in much better ranges.
I just played a 64 man match of bf3, which was running great with the OC, but at the end had temp maximum of
71-72 degrees.
Seems like I can push the 4.3 ghz and not have much to worry about. Though I'm not positive.
Any information I can contribute to help you all to help me push my overclock would be great to know. I followed a guide as far as offsets, and other settings in bios.
halp me internets.
Thx,
ColorBars
z77 extreme4
gtx 670 ftw sig 2
i5 3570k
hyper 212 evo
550w psu
16gb ram
Short and Sweet:
71-72 degrees.
halp me internets.
Thx,
ColorBars
