I've configured a cyberpowerpc.com machine (below) for a friend that wants to play Company of Heroes, Skyrim, and SWTOR. The only thing I'm concerned about is the power supply, not that it won't be enough but if there are any other complications like not enough amps for the GPU or if the power is somehow not "clean" enough.
This machine is at the limit of his budget because he still much purchase a monitor, keyboard, speakers, surge prot, etc. If there is dire consequence to this particular PSU selection, I'm sure he'll reluctantly address it with a better unit.
Also, he wanted help selecting a monitor under $250. So far the only thing promising I've found is the Samsung S23A350H. Good reviews have been hard to come by.
Case: * Azza Solano 1000 Full-Tower Advance Cooling Case w/ Dual 230mm Fan + Extra 3 Fans [+21]
Internal USB Extension Module: None
Neon Light Upgrade: None
Extra Case Fan Upgrade: Maximum 120MM Color Case Cooling Fans for your selected case [+15] (Blue Color)
Noise Reduction Technology: None
CPU: Intel® Core™ i5-2500K 3.30 GHz 6M Intel Smart Cache LGA1155 (All Venom OC Certified) [-96]
Venom Boost Fast And Efficient Factory Overclocking: Pro OC (Performance Overclock 10% or more)
Cooling Fan: CyberPower Xtreme Hydro Liquid Cooling Kit 240MM w/ Dual Fan(CPU & GPU Liquid Cool Capable, Extreme Overclcking Performance + Extreme Slient at 18dBA) [+20]
Coolant for Cyberpower Xtreme Hydro Water Cooling Kits: Standard Coolant
Motherboard: [CrossFireX/SLI] Asus Maximus IV Gene-Z Intel Z68 mATX Mainboard w/ ROG Connect, Lucid Virtu and Intel SRT & 7.1 SupremeFX Audio, GbLAN, HDMI, USB 3.0, SATA-III RAID, 2 Gen2 PCIe X16 & 1 PCIe X4 (All Venom OC Certified) [+94]
Freebies: None
Intel Smart Response Technology for Z68: None
Memory: 8GB (4GBx2) DDR3/1600MHz Dual Channel Memory Module [+20] (Kingston HyperX [+13])
Video Card: AMD Radeon HD 6950 2GB GDDR5 16X PCIe Video Card [+103] (Major Brand Powered by AMD)
Freebies: FREE Game - Shogun 2 Coupon: Total War
Video Card 2: None
Video Card 3: None
Multiple Video Card Settings: Non-SLI/Non-CrossFireX Mode Supports Multiple Monitors
Power Supply Upgrade: 700 Watts - XtremeGear SLI/CrossFireX Ready Power Supply
Hard Drive: 1TB SATA-III 6.0Gb/s 32MB Cache 7200RPM HDD (Single Hard Drive)
Data Hard Drive: None
Hard Drive Cooling Fan: None
External Hard Drive (USB3.0/2.0/eSATA): None
USB Flash Drive: None
Optical Drive: Pioneer BDR-206BK 12X Blu-Ray Writer (Black Color) [+99]
Optical Drive 2: None
Sound: HIGH DEFINITION ON-BOARD 7.1 AUDIO
3D Vision Glasses: None
LCD Monitor: None
2nd Monitor: None
3rd Monitor: None
Speakers: None
Network: Onboard Gigabit LAN Network
Network Switch: None
Keyboard: Xtreme Gear (Black Color) Multimedia/Internet USB Keyboard
Mouse: XtremeGear Optical USB 3 Buttons Gaming Mouse
Mouse Pad: None
Gaming Gear: None
Extra Thermal Display: None
Wireless 802.11B/G Network Card: None
External Wireless Network Card: None
Wireless 802.11 B/G/N Access Point: None
Bluetooth: None
Flash Media Reader/Writer: INTERNAL 12in1 Flash Media Reader/Write
Freebies: None
Video Card 2: None
Video Card 3: None
LCD Monitor: None
2nd Monitor: None
3rd Monitor: None
Speakers: None
Mouse Pad: None
Gaming Gear: None
Bluetooth: None
