Quick power supply question!
briovaz
177
hi,
i calculated the power needed to my rig using the antec psu calculater. it said that i only need 547w power supply to run my rig. now im thinking to buy a 600 w power supply. will it fry my rig because its more than the recommended power supply? please help. thanx in advance! :wahoo:
Nice!
Look for a case with good airflow from Antec or CoolerMaster.
I don't know your budget or taste but here's some case suggestions that could also accommodate future builds comfortably.
http://www.newegg.com/Product/Productcompare.aspx?Submit=ENE&N=100007583%2050001333&IsNodeId=1&bop=And&CompareItemList=7%7C11-129-042%5E11-129-042-TS%2C11-129-066%5E11-129-066-TS%2C11-119-215%5E11-119-215-TS%2C11-119-233%5E11-119-233-TS
Antec,Corsair,Seasonic,and XFX offer reliable quality psu's.
You could get by with a 450-500W unit but it's more cost effective to spend a little more and buy something you can grow into and keep longer.
A 600-650W would be more then enough and allow for future expansion such as a second or more powerful gpu.
http://www.newegg.com/Product/Productcompare.aspx?Submit=ENE&N=100007657%2050001669&IsNodeId=1&bop=And&CompareItemList=58%7C17-371-031%5E17-371-031-TS%2C17-139-005%5E17-139-005-TS%2C17-151-096%5E17-151-096-TS%2C17-207-010%5E17-207-010-TS%2C17-207-007%5E17-207-007-TS
