[Quick question] - Power supply to match case
Jpeppa
40
Hey there.
I'm having trouble finding a power supply that matches the physical dimensions of this case. I've tried multiple ATX power supplies but they all seem to be JUST a tad to big to fit safely in the unit...
http://www.newegg.com/Product/Product.aspx?Item=N82E16811320001
This is my case, I have never come across anything like this before so I'm not sure if I'm just overlooking something small. ANy recommendations would be appreciated.
* Also, it's a midrange gaming system so 500w+
Thanks in advanved!
That case takes any standard atx power supply. unless you're buying a special 1000w+ extra long powersupply (silverstone makes one) then any atx poersupply will fit in that case.
edit
anyone of these will fit in that case...
Thank you!
Not sure what the hell what was wrong with the others I tried, granted they were from another machine... though almost positive they were not proprietary.
Anywho, I appreciate the quick reply.
