Quick tips for my PC build
Dec 5, 2017
These are the parts that I ordered today. They will be here Thursday. I am wanting to make sure that my 400 watt evga osu will support this and that everything is compatible
PCPartPicker part list: https://pcpartpicker.com/list/TDvCf8
Price breakdown by merchant: https://pcpartpicker.com/list/TDvCf8/by_merchant/
CPU: Intel - Core i7-7700K 4.2GHz Quad-Core Processor ($312.88 @ OutletPC)
CPU Cooler: Cooler Master - Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($19.99 @ Newegg)
Thermal Compound: ARCTIC - MX4 4g Thermal Paste ($5.78 @ OutletPC)
Motherboard: MSI - Z270-A PRO ATX LGA1151 Motherboard ($90.88 @ OutletPC)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory ($194.89 @ OutletPC)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($46.89 @ OutletPC)
Video Card: EVGA - GeForce GTX 1060 6GB 6GB GAMING Video Card ($259.99 @ B&H)
Case: Deepcool - TESSERACT SW ATX Mid Tower Case ($36.99 @ SuperBiiz)
Power Supply: EVGA - 400w
Total: $1001.27
Generated by PCPartPicker 2017-12-05 23:49 EST-0500
400W is tight for your build.
You will have really to depend on best quality PSU to do that.
Not all eVGA PSUs are goog...some are not
I would recommend to get a bit more e.g. 500W just to make sure.
but...hmm..in all of your link I see 600W and not 400W...600W will do just fine
I have the 400w here. I just ordered the 600w today all my parts will be here tomorrow and Friday. Everything will be here tomorrow except the gpu and DVD/CD drive
I appreciate all of y'alls answers it helped me to go ahead and buy the 600w psu. This is my first PC build and I'm super excited to see how it all turns out
Compatible, yes. Performance wise, depends on what games you play and what settings you're OK with. You'll want to keep resolution at 1080p. A 1060 6GB will play most games at 60 FPS or more at max settings, but some games it won't.
That is why going forward I recommend a 1070 for those whom want 60 FPS at max settings on all games.
https://www.techpowerup.com/reviews/NVIDIA/GeForce_GTX_1060/14.html
