Question QuickCPU - CPU Base speed 2.30Ghz stuck at 2.20 Ghz by default
ShangWang
617
I want the my base speed to return without having to use speedshift, it seems that for some reason QuickCPU won't let me change my max Ghz past 2.20 when not at "best performance" on the windows slider even when I change the speedshift settings myself.
Is there any way to reset the QuickCPU applied settings without a system restore? Uninstalling the application after applying my manual settings does not seem to work and I'm stuck at 2.2 Ghz when not at "best performance"
Power management settings are typically the corporate. I would set that option to max performance and see if there is a difference. I would update bios as a bug could also cause that problem.
I have already reset my power plan, I am just using balanced mode. Bios is definitely not the issue either. As I mentioned I can use the base frequency on "best performance" but not any other slider mode which is my issue.
