Build Advice Quiet build with a 9800X3D CPU and a 5090 GPU ?
May 7, 2025
Hello guys. I would like to build the quietest build with good temps if possible. I need help with case, aio, extra fans or different fans if default are bad. I dont care about rgb, dont need it, my priority is it to be very quiet and not burning my floor. Dont have budget because I have no idea if its possible with a lot of coolers and cases or only premium expensives ones. Thanks.
CPU: Ryzen 7 9800X3D
GPU: ROG Astral 5090
MB: ROG 870 Hero
PSU: Corsair HX1500i
SSD: Samsung Pro 990
Case: ?
AIO: ?
Extra fans: ?
With that kind of hardware - doesn't happen (normally, that is).
Both R7 9800X3D and RTX 5090 are top-end hardware, which consume a lot of power (GPU especially) and in turn, produce a lot of heat. And to cool said heat, it needs plenty of cooling, which creates airflow noise.
So, normally, you will have noise.
Now, if you are all about quietness and money isn't an obstacle, then best solution for you would be liquid immersion cooling.
Here's video to preview such cooling:
View: https://www.youtube.com/watch?v=2Q0bLo5nSsU
And here's the Hypertec site: https://hypertec.com/immersion-cooling/
Sure, they usually do server builds, but you can either convert your setup into server rack and use their cooling solution, or maybe, (if you throw enough money at them), they are willing to build you single system immersion cooling setup.
Now, based on how it is set up, you need to alter your home layout a bit (drill holes through the wall so that liquid tubes can go to the heat exchanger) but otherwise, this immersion cooling setup would guarantee 0 dB(A) build for you.
So, contact the firm and discuss your options with them.
Reactions: Misgar
Noise comes from fans spinning at high rpm's.
Fans are necessary to move heated component air out of the case.
Your HX1500i is a good start. It will be loafing in the middle third of it's range and The fan might not even have to turn on.
The key for quiet is to get a good case with good airflow.
Lian li has a case with two front 160mm intakes that should be very quiet:
https://www.newegg.com/black-lian-li-lancool-atx-mid-tower/p/2AM-000Z-000A8
I would think you can turn off the RGB lighting.
Or, look for a case with 3 front 140mmm intakes.
Perhaps like this Phanteks:
https://www.newegg.com/black-phanteks-xt-mid-tower/p/N82E16811854132
Probably the best and quietest suitable cooler might be the Noctua NH-D15 G2:
Custom water cooling is the best option if you are not constrained by budget as you can just add more radiators and fans to the problem. Custom water cooling is expensive, difficult to build, and require maintenance that normal system just don't require. Pretty much any 5090 will have high fan due to its crazy 600w max power consumption.
Reactions: Flayed
If you go down the "quiet computing" rabbit hole you will never find the end.
Fans can have tonal differences that will feel different.
I recently tested my setup with cinebench(14900K), CM HAF XB evo, 2 noctua 140mm 800rpm intakes ana NH-D15s.
The case sits to my left, an arm length away and it was inaudible. to me, that is, I admit to being hard of hearing.
My point is how good do you need to be?
With a good cpu cooler, a robust graphics card will be the main source of noise.
For a case I recommend the BeQuiet Silent Base 802 BG039 model. I use mine with 8 Noctua NF-A14x25 G2 PWM fans (4 in 4 out) and set them for a 25 percent idle speed until temps reach 80C. I also use a Noctua NH-D15 G2 cooler, but an Arctic Freezer III Pro 360mm AIO will also work well. With the Arctic I found it best to use the 3 way cable they provide so that I can control the speed of the radiator fans to limit the noise until temps reach 80C.
https://www.newegg.com/be-quiet-atx...02-black/p/2AM-0037-00073?Item=9SIA68VCKF8599
MB: ROG 870 Hero
Case: ?
AIO: ?
Extra fans: ?
First, I am going to start by clearing up some misconceptions, and ask some clarifying questions. What do you consider quiet? You can certainly make a build reasonably quiet with the parts you are aiming to get. My profile signature is not updated, but I have a 5090 and a 5800X3D and my PC only becomes audible while playing games that pull more than 3-400w for the graphics card. I propose a build without a custom loop that should be fairly quiet.
One common misconception is that fans themselves are what make most of the noise, and that is false. When it comes to case fans, most of the noise is actually caused by the air being forced through the geometry of the case. Case fans in isolation rarely make more than 30-35db on their own, even at 2000-3000 RPM. Dust filters and the geometry of the front air inlets of a case are often what causes most noise when air is pulled through it. This all means that fan selection and case selection are vital to get a quiet PC.
You will still want really low noise fans that are made with LCP for rigidity and better tolerances. We should start by replacing all fans that come with the AIOs, and the case fans with Phanteks T30s where applicable. They are nearly as performant as high RPM louder fans like the Arctic P12/14 Max's but are much quieter with good static pressure.
The next consideration should be the case. The Antex Flux case is particularly quiet in all the testing I have seen and is large enough to fit everything you need.
The AIO for the CPU is the next consideration. We will be replacing the fans on any AIO we get anyways, so a high performance pump and radiator with a good long warranty is what we are after. The AIO that fits this mold, IMO, would be the Arctic freezer III 360mm.
The Asus astral graphics card is not particularly quiet, but if you get the LC version that comes with an internal pump and radiator we can alleviate a lot of the peaking sounds of the non-LC version while its under load.
So if we get two 3 packs of phanteks fans and put them on the CPU's and graphics card's radiators we can minimize the sound. Add in three additional single T30 120mm fans, two for bottom intake, and one for rear exhaust and you are golden. The AIO for the graphics card should be mounted on the top of the case as exhaust, and the AIO for the CPU be mounted in the front as intake with the tubes oriented towards the top of the case. The phanteks case also comes with a fan controller as well, so you can use that for all the fans in the case, or you can plug them all into the motherboard and control them via BIOS, either way will work great.
This setup should ensure the fresh air is being taken in by the CPU radiator and exhausted into the case to then be used by everything else. You do not want the graphics card radiator to be the case intake at the front because then it will dump 600w of heat into the case for the motherboard, card VRM/memory, and CPU radiator.
If you are in the USA then this is what the build would look like as far as cost. I would expect this build to not go too far beyond 40-45 decibels while under full load with the fan curves tweaked for quiet operation. Also consider hysteresis on all the fans so the ramp up and down are much more gradual and not as sudden.
PCPartPicker Part List
CPU: AMD Ryzen 7 9800X3D 4.7 GHz 8-Core Processor ($472.02 @ Amazon)
CPU Cooler: ARCTIC Liquid Freezer III Pro 360 77 CFM Liquid CPU Cooler ($84.99 @ Amazon)
Motherboard: Asus ROG CROSSHAIR X870E HERO ATX AM5 Motherboard ($640.99 @ Amazon)
Memory: G.Skill Trident Z5 Neo RGB 96 GB (2 x 48 GB) DDR5-6000 CL28 Memory ($424.99 @ Newegg)
Storage: Western Digital WD_BLACK SN8100 2 TB M.2-2280 PCIe 5.0 X4 NVME Solid State Drive ($279.99 @ Amazon)
Storage: Western Digital WD_Black SN850X 8 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($619.95 @ iBUYPOWER)
Video Card: Asus ROG Astral LC OC GeForce RTX 5090 32 GB Video Card ($3719.99 @ ASUS - OOS)
Case: Antec FLUX PRO ATX Full Tower Case ($179.99 @ Amazon)
Power Supply: Corsair HX1500i (2025) 1500 W 80+ Platinum Certified Fully Modular ATX Power Supply ($349.99 @ B&H)
Case Fan: Phanteks PH-F120T30 101 CFM 120 mm Fans 3-Pack ($114.99 @ Newegg)
Case Fan: Phanteks PH-F120T30 101 CFM 120 mm Fan ($39.99 @ Newegg Sellers)
Total: $7122.85
Generated by PCPartPicker 2025-06-13 16:27 EDT-0400
Reactions: Flayed
