Quiet CPU Cooler
petrolhead
9
Hi
First post
Have P4 3.4gig 775 and am looking for the quietest cooler.
Don't play games but somtime edit video. Not wanting water cooling
Anyone has any suggestions as I need as quiet as poss
Ta
Have you seen <A HREF="http://www6.tomshardware.com/cpu/20041213/index.html" target="_new">http://www6.tomshardware.com/cpu/20041213/index.html</A> Just make sure you get the fanmate2. I would get the alcu model.
I just got Zalman CNPS7000B-cu with fanmate2. The temp dropped bu more then 8C degrees. Just waiting for those 100 hours for Arctic Silver 5 to set.
CNPS7000B-cu or the CNPS7000B-alcu
alcu might actually cool better because aluminum dissipates heat faster, and its pretty cheap. if you have good case circulation you can usually put it on low fan speed, and its literally inaudiable
<A HREF="http://www.albinoblacksheep.com/flash/you.html" target="_new">please dont click here! </A>
Zalman offers an adapter allowing you to use the CNPS7000 on socket 775. The CNPS7700 is natively socket 775 and it’s a more efficient cooler because it’s larger, which is of course also it’s disadvantage. I’d recommend the CNPS7700-Alcu, aluminium DOES NOT conduct heat better than copper, but it’s lighter and not as expensive, still a CNPS7700-Alcu cools more than a CNPS7000-Cu which both costs and weighs about the same, you should be able to use that one with low fan-speed with your processor. If you want serious cooling go for the CNPS7700-Cu, it weighs over 900 grams, or about 2 ibs, however.
