G g_dimitri Distinguished Jan 29, 2014 78 0 18,640 Nov 24, 2014 #1 Hi, I have an FX-6300 and the stock cooler noisy and not very efficient. I'm looking for a decent priced fan to replace it that would be quiet and better functioning. Thank you
Solution Eximo Nov 24, 2014 Depends on how much space you have in the case. Cooler Master Hyper TX3 is inexpensive and fits in most slim towers and desktops. If you have a fairly large case, one of the better budget coolers is the Cooler Master Hyper Evo 212 (Or Hyper 212X)
Eximo Titan Ambassador May 27, 2010 28,010 5,544 144,340 Nov 24, 2014 Solution #2 Depends on how much space you have in the case. Cooler Master Hyper TX3 is inexpensive and fits in most slim towers and desktops. If you have a fairly large case, one of the better budget coolers is the Cooler Master Hyper Evo 212 (Or Hyper 212X) Upvote 0 Downvote Solution
G g_dimitri Distinguished Jan 29, 2014 78 0 18,640 Nov 30, 2014 #3 Eximo : Depends on how much space you have in the case. Cooler Master Hyper TX3 is inexpensive and fits in most slim towers and desktops. If you have a fairly large case, one of the better budget coolers is the Cooler Master Hyper Evo 212 (Or Hyper 212X) Thank you Upvote 0 Downvote
