Quietest 80mm fan
pebbleberries
Respectable
May 17, 2016
342
Does anyone know, what is the quietest 80mm fan out there?
I'm thinking between a Be Quiet Pure Wings 2 and a Silenx Effizio Thermistor.
It also needs to actually move air too. This is going to be in an amplifier running max speed all the time when it's on.
Case Fan: Noctua NF-R8 redux-1800 31.4 CFM 80mm Fan ($14.88 @ OutletPC)
Case Fan: Noctua NF-A8 FLX 29.7 CFM 80mm Fan ($15.88 @ OutletPC)
Modding the fans is easy, you'll only need the power and ground to match up, the tach wire is essentially useless. I like the Noctua, but honestly, anything below 20 db(A) is considered silent. Whether or not this'll translate in enclosed space like the amp is unknown, but the silentwings would work too. Nice thing about Noctua fans is they usually come with LNA/ULNA adapters that'll change fan voltage from 12-9-5v lowering both speed and volume if you find it necessary.
are you sure that you won't have to do some soldering to replace the fans? or if you're comfortable with soldering...and they are in fact soldered...any fan you put in there might run max RPM anyways so i would shop for one that has a lower RPM listed in the specs? that's all i got brudda
I believe they should. They are only 3wire adapters, 12v+, ground and a tach wire. Basically just a resistor online on the 12v+ to drop the fan voltage to 9v etc. Will have nothing to do with the tach wire, since that's only an rpm signal wire. Pwm fans have no need for a voltage adapter since they work on 12v constant.
