Quietest Cpu cooler? (Stock fan sounds like a jet taking off)
Aezritte
I'm using AMD X6 1055t and its stock fan cooler, which is so freaking loud when running at 100% like ~ 4000-5000 rpm.
So, im looking for a new one.
TX3
Hyper 212
THERMALTAKE CONTAC 21
XIGMATEK LOKI II
DEEPCOOL ICEEDGE 400FS
Corsair H60
I wonder which one make the least noise?
Wii there be any different compared to the AMD stock cooler?
the H60 is a water cooler though. Will it quiter than the others?
Thank you in advance.
I agree with above. Buy the CM Hyper 212 EVO. It's $30, and really good. It's also really quiet. It also works quite well, and it's beaten with only an H100i from corsair or dual+ radiators and a custom loop.
Thank you for replying, everyone. I bought the CM Hyper 212X and really satisfied.
Its fan speed @ 100% sounds better than the stock cooler @ 50% which is bareable, and even cooler.
BUT usually, it runs FAR less than that unless I force it to. (paired with Phenom X6 1055t) :)
Im using my pc at the bedroom and now even gaming at night it still sounds like ninja...
Thank you again. 😀
