Quirky Wireless Connection
debbielc21
Hi. I have set up a wireless G router to my cable internet and installed a wireless adapter on my desktop computer. I was initially able to get on some websites and not others and then miraculously one day I was able to get on all the websites I tried. Then just recently it went back to the same problem with limited website viewing and sometimes the internet page will freeze when I attempt to go to a "non preferred" website :wahoo: Anyway, the signal shows connected and signal strength excellent. Any advice that you can provide would be greatly appreciated. Thanks.
~Debbie
gstefanick
63
Are you having this same issue when you disable the wireless and go on the wire?
debbielc21
No, when I disable the wireless and go on the wire, everything works fine. It seems to be a problem that comes and goes too. Thanks.
~Debbie
