Hi there I just bought a new motherboard to fit my i5 2500k socket aswell as upgrade to USB3 and able to handle 1600Mhz RAM. I was advised to buy the ASUS P8 Z77-V LX I have a fairly recent PSU, its a Corsair 850W Dual Heat Pipe. I am unable to find the 8pin ATX power cable on it, for my old Motherboard I only had a 4pin plugged in as on the board it was only 4pin not 8. However I have set my new one up with only a 4pin plugged in, it runs fine and I cant yet see a problem with it but I am worried that it may damage my CPU (I Dont have my 2500k Overclocked). Would it be safe to leave the 4pin cable plugged in or would you recommend buying an adapter? I really didn't want to have to buy another PSU.
I really appreciate anyone who has the time to reply,
Thanks
(I play all sorts of games on it from BF4, DayZ, Crysis etc) - Added info if it effects the power usage at all.
Spec:
CPU: i5 2500k 3.3Ghz
Motherboard: ASUS P8 Z77-V LX
RAM: Kingston 1333Mhz
GPU: Zotac GTX 780Ti
PSU: Corsair 850W
Thanks
Spec:
PSU: Corsair 850W
