R Side of Headphone is not working
G
Guest
Guest
there is something wrong with my headphone, when connected to pc, the R side doesn't work, but when i connect it to the TV it works :-S i dunno if its a kind of Hardware problem or software problem :/
If this is a desktop computer, are you using the sound output socket at the rear of the computer (direct to the motherboard) or a front panel extension ? Have you tried connecting a different pair of headphones or amplified speakers ?
i dont have speakers, i put it direct to the motherboard, and i used an earphone it didn't work on 3d sounds or how they call it ....
