R4 Fractal Power Sw question
Snow Mandalorian
Hey all, I just moved to a Fractal R4 and I *think* I connected everything properly, but the computer won't power on. My only guess is it has something to do with the R4 power switch cable being smaller than my motherboard's. Here's what I mean:
Notice that the case cables don't fully cover the white panel. Could this be the cause? If so, what can I do?
I need to know the motherboard make and model so I can look up its manual to see where the cables go.
In the mean time, try moving those two cable on the right one pin to the left.
Here are the serial numbers on the motherboard's sticker:
61-MIBDR1-03 MB1
And this number is right under the barcode:
PG130003MB 100008A
The PSU plugs into the motherboard via a 24 pin connector.
The actual power panel has 20 pins.
Hope that's the info you need. I just for the life of me can't get it to work. :-/
The power switch of the case only has two pins. A black and a red.
The motherboard's light is green, if that's helpful to know. I went over everything again, took out the motherboard and made sure there's no metal touching it from behind, the power cables are all plugged in, etc. The power supply is also only a month old, and it was working perfectly prior to switching over to the new case. I'm just not sure what could be wrong.
