R5 1400 Overclocked Temps reading accuracy
ryuki7
47
CPU: R5 1400 - Overclocked to 3.9GHz
Motherboard: ASUS Prime B350 Plus (latest BIOS)
GPU: Gigabyte GTX 1070 G1 Gaming
RAM Corsair Vengeance 16GB 3000 MHz (got it clocked at 2933 MHz)
So I was able to overclock my Ryzen 1400 to 3.9 GHz. I use a Cooler Master Hyper T4. When stress testing using Prime 95, I was getting 80 degrees tops using NZXT Cam and Hardware Monitor. However, when I look at ASUS AI Suite, I was only running at 65 Degrees on the CPU. Which one is more accurate?
when in doubt believe the higher temp. Your better off believing the higher temp then pushing your CPU to far. I would tend to believe hardware monitor or openhardwaremonitor (both are related to one another) then asus ai suite. You could also try another tool and see what it says.
