Question r5 3600 overheating on idle with watercooler and stock cooler
Sep 5, 2020
already tried reseating the coolers, reapplied paste, it goes down 10 or so C slowly then it jumps 10 C instantly. tried clearing cmos,
Rae Nelvin
Great
Aug 25, 2020
123
14
85
r5 3600, stock cooler and also tried nzxt x53, msi gaming plus max, one day it just started overheating randomly. im using nzxt cam, ryzen master and also hwinfo64
Can you report your Ryzen Master status? The EDC(CPU)? Did you do any changes on the Ryzen Master?
dorsai
Reset the BIOS to defaults...enable memory XMP support, option your boot drives, and leave everything else on Auto...make sure PBO is off as it adds little if anything to performance for 3rd gen Ryzen while adding heat.
If you've changed Windows Power Plan settings return that to stock also...use the Ryzen Balanced plan.
